74 Camaro sub frame connector question
lmccoll2
Post by lmccoll2 »
Hello,
Can anyone tell me about installation of sub frame connectors for a 74 Camaro? Which is easiest to install, bolt in or weld? If you use bolt in, do you have to unbolt the subframe of the car to install the sub connectors?
Thanks for any help.
Larry
af2
Re: 74 Camaro sub frame connector question
Post by af2 »
lmccoll2 wrote:Hello,
Larry
Larry, weld them in and be done! Bolts are weak unless you weld a round tube inside the square tube so it doesn't collapse!
