Brake system????
Brake system????
Who can help me design the hydraulics part, of a disc drum 3500 lb. drag car, that runs in the mid. 10's @ around 120-130 mph? I am looking for advice on M/C bore size, (i am going to use a Strange Eng. M/C) residual valves, prop valves, do I use the stock combo. valve? I am using the Aerospace ac-205 front disc kit, and the stock drums on the rear. Any help in this area would be greatly appreciated, as the braking as I have it set up now is atrocious.
Brakes.
rallye. I also go mid 10s @ 129mph. I have the stock front disc brakes, and a touch larger chrysler rear drum on the rear. Here in Albuquerque, we have a decent in length , but a little lumpy shut down area. Anyway, It seems your car has the ability to accelerate faster [and most do] than stop. That too, is dangerous. Good Luck. Dan.
- af2
Mine is drag race only also. (Notice Avatar) 33 Willys Coupe.rallye bob wrote:Just to clarify, this is for a drag race only system/car...af2 wrote:The smaller the M/C bore the more pressure. I run a 1" bore with 4 wheel 4 piston disks. Works good.
What are the other components to your brake system?
Is your m/c higher than your calipers (mine is)?
I use a Wilwood 1" master that is higher than the calipers.
I am using 4 piston Outlaw calipers front and 4 piston Wilwood superlites rear. There is a line lock also that I don't use. Other than that it is very simple and straight forward.
GURU is only a name.
- af2
Re: Brake system????
I hit quote this time!rallye bob wrote:Who can help me design the hydraulics part, of a disc drum 3500 lb. drag car, that runs in the mid. 10's @ around 120-130 mph? I am looking for advice on M/C bore size, (i am going to use a Strange Eng. M/C) residual valves, prop valves, do I use the stock combo. valve? I am using the Aerospace ac-205 front disc kit, and the stock drums on the rear. Any help in this area would be greatly appreciated, as the braking as I have it set up now is atrocious.
Make sure the rear output doesn't have residual 2lb valve installed before you add them!!!!
I would NOT use the factory combo valve! Orifices in the original slow the pressure to the calipers. Just make sure the drums get 2lbs residual and you will be fine.
The braking performance of any vehicle depends on the ability of the tires to transmit braking forces to the ground.
The force transmission of the tires is depenpent on vertical loading at each tire, tire to ground slippage and friction coefficient of tire and ground.
The vertical tire loading is modified (rear to front) as a function of longitudinal weight transfer. The amount of weight transfer results from the vehicle total weight, center of gravity height, G force and wheelbase.
If a substantial amount of weight is transferred to the front, the rear tires cannot contribute to stopping the vehicle and only the front tire must do the entire job. Pretty tough on front brakes and front tires.
A proper brake design will provide braking forces to each wheel in proportion to the load capacity of each tire.
The easiest way to test a brake system is to try to lock up all four wheels simutaneously. If the distance between the front skid mark and the rear skid mark is equal to the length of the wheelbase, the brakes are working properly.
Engineers will use a wheel speed sensor at each wheel and measure wheel slippage to the ground.
Designing a proper brake system on paper before buying any parts is the smart path. But it does take a great deal of vehicle information such as: vehicle weight, wheelbase, center of gravity height, brake/drum diameter, tire diameter, tire coefficients, master cylinder size, caliper and wheel cylinder size, friction material coefficients, brake bias, etc.
And then there is the task of trying to keep the tires on the ground.
