Ive got a pile of holleys sitting around and one that i want to use has the throttle lever missing from the throttle shaft.
I have looked at the other parts carbs that i have and all the throttle levers have swedged ends on the throttle shafts and dont look like they can be easily removed.
How does one go about removing and reinstalling throttle levers on 4150 holleys?
I would have just ground the ends down with my dremel but i dont think that i could make the new/other lever stay on without being able to swedge the new throttle shafts.
Please and thank you
God bless
-Shred
Throttle lever removal 4150.
- jmarkaudio
You could replace the throttle shaft and arm as an assembly. If you don't want to rob another carb, go to www.blp.com. All the Holley parts you need.
Mark Whitener
www.racingfuelsystems.com
____
____
