Can titanium be welded to SS?
I've got some Ti bike mufflers that I need to modify, and I am wondering before I go about ruining them, if they can be successfully welded to stainless or regular steel. If a weld won't stick, I'll just have to clamp them over the tube. Oh, I'm using a gas wire feed MIG welder.
- DavidHarsay
- Alan Roehrich
Thank you for your replies. I would've probably hacked the pipe off by the canister, then found I couldn't weld it if I hadn't gotten answers, therby junking a $50 set of pipes.
I'm installing stock Yamaha R1 cans in front of each rear tire on a Suzuki Swift GTi. It's basically a detuned car version of a GSX-R twincam 1300, so they should sound incredible.
Again, thank you.
Scott
Again, thank you.
Scott
- af2
You made a good choice!crazyman wrote:Thank you for your replies. I would've probably hacked the pipe off by the canister, then found I couldn't weld it if I hadn't gotten answers, therby junking a $50 set of pipes.
Again, thank you.
Scott
GURU is only a name.
I cut off the curved pieces tonight. I left about 4 inches of pipe out of the mufflers. I tried welding the cutoff just for grins. It didn't weld nice at all. It did stick, but looked like bird poo, and crackled like rice crispies when it was cooling off.
Now with my pipe stubs, I can clamp pipe over it. Again, thanks for saving me headache.
On a side note, this website seems to be a wonderful place to learn new things. Thank you for the environment.
Scott
Scott
