What has happened to proper nomenclature
Open
exhaustgases
Re: What has happened to proper nomenclature
Post by exhaustgases » Mon Aug 21, 2017 5:04 pm
So lets see force is measured in what? And pressure is measured in what? USA stuff only not other units.
pressure
the continuous physical force exerted on or against an object by something
force
strength or energy as an attribute of physical action or movement
So according to the definitions the best one is pressure, since when measuring the spring, that is the definition that best applies.
So SPRING PRESSURE is the winner.
It is only FORCE when the engine is running.
Circlotron
Post by Circlotron » Mon Aug 21, 2017 8:11 pm
Up to x figure and beyond... :roll:
Post by pdq67 » Sat Sep 02, 2017 8:51 pm
Please disregard, I got, "fubared", is all!!
stealth
Post by stealth » Sun Sep 24, 2017 10:15 am
All of Europe consider our "American" pronunciation of aluminum to be barbaric...
Top 5 offensive pronunciations has to include calling NOS ....Naz.... this one just hurts at multiple levels
stealth
Post by stealth » Sun Sep 24, 2017 10:22 am
stealth wrote:All of Europe consider our "American" pronunciation of aluminum to be barbaric...
Not to mention the term "OIL Ring"....
EVERONE KNOWS it's proper name is...... peripheral abutment ring
http://www.google.sr/patents/US20130234400
exhaustgases
Post by exhaustgases » Wed Sep 27, 2017 7:30 pm
Oil control ring.........When used in regard to an internal combustion reciprocating engine.
Circlotron
Post by Circlotron » Mon Oct 16, 2017 8:05 am
I get annoyed when someone says a certain statement is a mute point instead of a moot point.
https://en.oxforddictionaries.com/definition/moot
joe 90
Post by joe 90 » Mon Oct 16, 2017 4:20 pm
pressure
force
What a load of bollocks.
Force is measured in pounds or newtons.
Pressure is force per unit area so pounds per square inch or newtons per square centimetre.
exhaustgases
Post by exhaustgases » Mon Oct 16, 2017 5:21 pm
pressure
force
All my stuff is from dictionary. Maybe you should volunteer to rewrite them.
The definition says what it is. Not how or what ever the certain units of measure you wish to use to do so. Simple stuff, not rocket science.
So yeah its like bollocks to even post that.
joe 90
Post by joe 90 » Mon Oct 16, 2017 6:39 pm
Here you go.
I don't think you read it properly
https://en.wikipedia.org/wiki/Pressure
Definition[edit]
Pressure is the amount of force applied perpendicular to the surface of an object per unit area.
On the subject of proper nomenclature, the "oversize " bearings thing seem to be catching on.
I guess that's what happens when kids get access to computers. Or maybe it's just people with Engrish as their third language?
GARY C
Post by GARY C » Mon Oct 16, 2017 7:58 pm
As it turns out nowomenclature anymore either! #-o
Websters printing presses must be running around the clock to keep up. :D
Walter R. Malik
Post by Walter R. Malik » Tue Oct 17, 2017 9:48 am
Although most bearing shells are UNDERSIZE there are those which ARE oversize; especially the O.D. of some.
exhaustgases
Post by exhaustgases » Fri Oct 20, 2017 5:54 pm
Here you go.
Definition[edit]
Wikipedia is the hot talkers dictionary, where many know nothings can put what they "think" something is and call it gospel.
Here is a better source
https://www.merriam-webster.com/dictionary/pressure
joe 90
Post by joe 90 » Fri Oct 20, 2017 6:33 pm
Quoted
b :the force or thrust exerted over a surface divided by its area.
It says the same thing.
exhaustgases
Post by exhaustgases » Sat Oct 21, 2017 12:48 am
the application of force to something by something else in direct contact with it :compression
I guess you missed it.
