TH350 trouble
Transmission to Rear-end
MelloYello
TH350 trouble
Post by MelloYello » Tue Oct 18, 2005 6:53 am
I have a th350 that slips shifting into 3rd gear under WOT and also sometimes while in 3rd gear and you go WOT it will slip. I should say that under every other circumstances the tranny performs flawlessly and 1/2 throttle shifts into 3rd are no problem. The 1-2 shift is perfect , tranny has a B&M shift kit with a 10" 3500 converter, adjustable modulator valve, milage is unknown on the tranny. Its behind a fairly hot sbc and 2900# car. Any ideas ?
SupStk
Post by SupStk » Tue Oct 18, 2005 10:13 am
If this problem just didn't crop up after doing valve body work, my guess it is time for a rebuild.
MelloYello
Post by MelloYello » Wed Oct 19, 2005 12:02 am
Well that might very well be the bottom line, tsk tsk :|
