Converter Speed
Transmission to Rear-end
Guest
Converter Speed
Post by Guest » Fri Apr 23, 2004 11:13 pm
If you have dyno numbers, where do you put the stall speed relative to the torque peak? Thanks for your help
tk
Show Guest
Show Guest
Re: Converter Speed
Post by tk » Sat Apr 24, 2004 10:55 am
Anonymous wrote:If you have dyno numbers, where do you put the stall speed relative to the torque peak? Thanks for your help
Frank Lupo from Dynamic converters told me 200 rpm over the max torque.
Tom K.
www.tkrace.com
tkracehead@hotmail.com
I love motorsports because all other sports require only 1 ball!
Cheap...Powerful....Reliable...Choose only 2 of the 3
speedtalk
Site Admin
Site Admin
Post by speedtalk » Sat Apr 24, 2004 11:00 am
Well, it depends on if you want to go fast or be consistent.
To go fast, fax your dyno sheets to the converter company. French Grimes, though not a drag guy, give good advice on this, shift points and trap rpm. http://speedtalk.com/shows/032_french_grimes.html
To be consistent, you'll need something over the torque peak - depending on your shift and trap rpm, maybe way over. That's the trend.
Don Terrill
SpeedTalk Owner/Admin
dbusch
stall speed
Post by dbusch » Thu Dec 23, 2004 12:43 pm
for a 3 speed, a touch above peak tq, for a 2 speed, 500-700 rpm over peak tq is a starting point.
