Transmission Band adjustment
Transmission to Rear-end
1972ho
Post by 1972ho » Tue Jan 20, 2015 2:54 pm
How often should the bands be adjusted on dragrace cars
Re: Transmission Band adjustment
Post by Ken0069 » Thu Jan 29, 2015 12:25 pm
This isn't necessarily true for ALL transmissions but if you're running a PowerGlide with a trans brake then it will usually let you know when it needs adjusting, ie, it will try to back up when you press the brake button.
Coloradoracer
Post by Coloradoracer » Tue Feb 10, 2015 9:31 pm
Not too many transmissions used in drag racing run bands with an adjustment screw. Like Ken said with a glide, it will try to back up. On mine in my dragster, I check it about once a month and readjust it, just so it's not a concern on race day..
Mark Goulette
Authorized Amsoil Retailer
1972ho
Post by 1972ho » Sun Feb 15, 2015 1:06 am
Well that didn't work right I made the adjustment base on the believe that my trans case was a C-4,come to find out I have a C-5 case which calls for a different adjustment when you back off the the adjusting screw 4 1/2 turns for C-5 case 1 1/2 turns for C-4 case now I have to much drag on the band and the oil smells burnt.
Coloradoracer
Post by Coloradoracer » Sat Feb 21, 2015 10:04 am
Time to take it out and apart.....
Mark Goulette
