GM 7.5
Transmission to Rear-end
mitch
GM 7.5
Post by mitch » Wed Feb 25, 2015 7:52 am
Has anyone ever seen a GM 7.5 with no shim at all on the pinion. Got a 79 Buick That I am swapping the gears out on and when I pressed the old bearing off to reuse the shim it did not have one.My new gear is looking like it will take a .038 shim. All the ones that I have done in the past have always been real close to needing the original shim.It had factory 3.08 gears in it. I am replacing with Richmond 3.42.
Thanks Mitch
Supershafts
Re: GM 7.5
Post by Supershafts » Sun Mar 01, 2015 12:44 pm
no
We Race, We Vote!! Limotorsports.org
Supershafts.com
4spod
Re: GM 7.5
Post by 4spod » Sun Mar 22, 2015 10:15 pm
i did a rebuild on a 1988 trans am 7.5 aussi. rear end and i found the shim under the large bearing cup in the housing.
tresi
Re: GM 7.5
Post by tresi » Mon Apr 06, 2015 12:29 pm
Every one I've had apart had .030- .035 shim in them. Has anybody been in this rear end before?
