Chassis Dyno Testing
Transmission to Rear-end
BBO Omega
Post by BBO Omega » Sun Mar 22, 2015 4:39 pm
A little warning for my Gear Head buddies that spend time on the old Chassis Dyno:
TIRE USE ON A DYNO
Mickey Thompson tires which have been subject to use on a Dyno must no longer be used for subsequent, normal service. Use of Mickey Thompson tires on a Dyno will invalidate the tire warranty.
At no time should the following Mickey Thompson tires be used on a Dyno: ET Drag
ET Motorcycle
Pro Drag Radials
ET Street
ET Street Radial
ET Street Radial II
This is Mickey Thompson DRAG / STREET Technical Bulletin #8.
For more information regarding Mickey Thompson Performance Products ph: 330.928.9092
73 Omega, 468 BBO, 4.185 ICON Pistons,RR/Wenzler Heads with HS 1.7 rockers and PAC 1220X Springs,J&S 5-main Halo with Billet Caps, .590I .580E 242I 256E HR Cam, 1000hp Carb,2" x 3 1/2" headers,Coan 2900rpm Conv.,TH400,3.73 12 bolt,11.32/118
F-BIRD'88
Re: Chassis Dyno Testing
Post by F-BIRD'88 » Mon Mar 23, 2015 2:32 pm
Cannot blame them for warning against use on a dyno.
As the tire is subjected to excess tread and side wall bending when loaded against a round radius roller
wheel instead of a flat surface (the road).
Have not measured but I bet the tires gets real hot from the flexing distortion.
Its just too hard on the tires.
RednGold86Z
Post by RednGold86Z » Fri Mar 27, 2015 3:00 pm
We blistered the bejesus out of a set of Coker slicks once.
A few pulls won't hurt 'em usually, but make sure to do some cool down slow rolling so you don't end up with a flat spot.
