Th400 no second gear???
Transmission to Rear-end
Chipped tooth
Post by Chipped tooth » Fri May 01, 2015 10:30 pm
Well I got myself a Th400 that has a tci manual valve body reverse pattern.
It lost 2nd gear many years ago witch it rolled the sprag.... So I installed a different drum from another Th400 that also had the 16 element sprag. Worked fine for a few years but then sat for 5 or 6 years.
About 4 years ago when I removed car from storage it didn't have second gear again.... Well maybe 1 or 2 times but that was 4 years ago.
So I figured it rolled the sprag again, it acted like you popped it in neutral in second
So I pulled the sprag expecting to find it buggerd up again.
Not the case, it looked fine and drum looked good. I had already ordered a new 34 element sprag hence my previous post.
I installed it along with a Coan 9" 5000 stall converter.
Sprague free wheel turning clockwise with drag side up..... That's what my manual said.
Now it acts like it's still in 1 st upon second shift and then it acts as if it's binding in 3rd.... Wtf!
So I pulled the pan and nothing smells burnt or any heavy material in pan.
Pulled valve body and 're set the 1/8 gap on the spring and ball bearing. Was a little tite.
New filter and fill and it's the same damn thing......
How could a new sprag and converter cause such a issue?
Anyone have any advice on this?
bigfoot584
Re: Th400 no second gear???
Post by bigfoot584 » Sat May 02, 2015 8:28 am
You may try here in Hutch's transmission
section also for help, some good info.
http://www.yellowbullet.com/forum
Chipped tooth
Post by Chipped tooth » Sat May 02, 2015 11:23 am
Thanks Bigfoot, I was going to wait till Monday to post on YB if I didn't hear any ideas in ST
I'm going to pull the trans today and check it over a bit more.
Chipped tooth
Post by Chipped tooth » Mon May 04, 2015 7:04 pm
Update on my no second gear issue.
I pulled the trans apart and everything looked brand new, air checking the clutch packs revealed I had a massive leak from the intermediate piston.......
Both seals were broke to pieces.... Luckily I had a Th400 kit I could steal the seals from.
All is well now!
wyrmrider
Post by wyrmrider » Thu May 07, 2015 12:29 pm
all's well that ends well
easiest fix possible and no hard parts
Chipped tooth
Post by Chipped tooth » Fri May 15, 2015 12:49 pm
Definitely!
I was expecting the worst.
I can't believe it didn't burn up any clutches, seal was practically crumbling...
gowest
Post by gowest » Fri Jun 12, 2015 3:18 pm
Wondering if this worked well once back in the car. The seals make sense for a no second gear but doesn't explain the bind on the 2-3 shift.
Sprag installed upside down or rolled and locked up would cause this.
Marty
pitts64
Post by pitts64 » Sat Jun 27, 2015 8:49 am
My Turbo 400 was slipping bad in second, turns out the case was cracked, I'm going to look into a new case the next time around..
Alan Roehrich
Post by Alan Roehrich » Sat Jun 27, 2015 11:25 am
pitts64 wrote:My Turbo 400 was slipping bad in second, turns out the case was cracked, I'm going to look into a new case the next time around..
ATI Performance Products has the best TH400 case. Not cheap, but strong, and SFI approved, so no shields required.
pitts64
Post by pitts64 » Sat Jun 27, 2015 12:59 pm
Thanks Alan...
