Tremec T5 2.95 gearsets
Transmission to Rear-end
daimlersteve
Post by daimlersteve » Tue May 26, 2015 6:16 am
Hi Guys ,
Who is a reliable and cost effective supplier of the Z type 2.95 cluster/ input shaft and mainshaft gears ? After market ok as long as someone has had some experience with them and can recommend them
Also need a .8 / .82 fifth gear pair
I have to get them exported to New Zealand so they should be an established shop.
Cheers Steve.
autogear
Re: Tremec T5 2.95 gearsets
Post by autogear » Tue May 26, 2015 1:14 pm
An actual Tremec produced gearset is going to be hard to find and quite spendy for this. Try Kevin @ TheGearBox.org
He caters to a lot of this stuff and probably has the missing components from Asia you would need. Another option would be a G-Force conversion
daimlersteve
Post by daimlersteve » Tue May 26, 2015 3:38 pm
Thanks, the GForce option is over the top for this application of only 230hp.
the options in this part of the world are liMited.
Any other sources appreciated
steve
autogear
Post by autogear » Thu May 28, 2015 9:36 am
Other T5 guys:
Hanlon Motorsports in Pennsylvania
D&D Performance in Michigan
5speeds.com (Medatronics) in Florida
Zumbrota Bearing and Gear in Minnesota
All of them will ship overseas.
