Turbo 400 govornor adjustment..
Transmission to Rear-end
pitts64
Post by pitts64 » Sat Jul 04, 2015 11:52 pm
If I change the weights to the governor in my th400, will it change the part throttle shift points?
My trans doesn't shift soon enough with the electric kick down connected.. I'm looking for it to shift between 5000 to 5600 full throttle with no change to the part throttle shifts..
Thank you...
Alan Roehrich
Re: Turbo 400 govornor adjustment..
Post by Alan Roehrich » Sun Jul 05, 2015 12:08 am
Yes, it will. The governor controls shift points, period. If you raise the shift point with the governor (the only way to raise it appreciably) you raise it at all throttle settings. If your WOT shift points are too low, but part throttle is fine, then you do not have enough line pressure rise.
pitts64
Post by pitts64 » Sun Jul 05, 2015 9:02 am
The full throttle shift points are too high with the solenoid connected... Is it still a line pressure issue?
Thank you..
Alan Roehrich
Post by Alan Roehrich » Sun Jul 05, 2015 12:53 pm
It is probably a calibration problem. Isn't this the unit you posted about that has a Trans-Go kit in it? If so, try a Superior kit, possibly you may need a different valve body and a new separator plate to do that.
pitts64
Post by pitts64 » Sun Jul 05, 2015 1:12 pm
Yes, it has the Trans Go kit... I look into the Superior kit..
Alan Roehrich
Post by Alan Roehrich » Sun Jul 05, 2015 1:37 pm
One thing you must remember. A valve body and the associated valves, AKA the modulator and valve, and the governor and valve, together form a rather basic hydraulic "computer". As such, the WOT shift points and the part throttle shift points will always be proportional. So, for example, you cannot have the relatively high RPM part throttle shift points of a Corvette or Camaro LT-1 calibrated TH400 at part throttle, and then have the relatively low RPM shift points of a C-10 350 4 barrel calibrated TH400 at WOT.
Also, with an "automatic" (not full manual aftermarket) valve body, you do not want to disable the throttle input, the detent solenoid on a TH400, or the detent cable on a TH350. If you do, you eliminate the line pressure rise and lube increase at WOT. You risk slippage and poor shift quality, as well as failures of hard parts (planetaries, sprags, bushings, etc) related to lack of lube flow.
pitts64
Post by pitts64 » Sun Jul 05, 2015 6:04 pm
I always thought my car ran slightly harder with the electric solenoid connected.. The builder said it didn't matter if the electric was connected or not due to modifications he made...
pitts64
Post by pitts64 » Mon Jul 06, 2015 8:31 am
Here is the link to some of the modifications done, dual feel mod was one of them..
Jake did NOT build this transmission for me..
http://www.jakesperformance.com/TH400_Rebuild_Tech.html
