Short shift Camaro V6 T-5
Transmission to Rear-end
Caprimaniac
Post by Caprimaniac » Thu Jul 23, 2015 7:23 am
Hi, all.
Need advice here.... Put a t5 from a Camaro v6 behind a FORD v6. The trans/ engine- package seem to be mounted tilted in the Camaro ? Trans to member mount is tilted, therefore suspekt so....
HURST has a short shift for this trans. However, expect it to be straight up regarding to the Camaro body. and therefore need welding/tilting in ny application.
Have seen beat- lisings of shifters made w/ HURST basis and a tilted shifter supposedly ro a trans- swap like ths. I'd love if someone cold post up links to shifters that will fit straight info mye application.
Stock shifter has very long throw, and need a fix.
Thanks!
ChevyEFI
Re: Short shift Camaro V6 T-5
Post by ChevyEFI » Thu Jul 23, 2015 8:38 pm
Not suspekt. :D Just ergonomically ideal in a lot of GM platform cars.
You can disassemble and straighten the stub in some shifters for straight -up use. Maybe reverse the stub so it points driver side and fab a stick to match.
Or, S10 shifter which is quicker ratio (for a really long stick.)
Caprimaniac
Post by Caprimaniac » Fri Jul 24, 2015 4:47 am
Thanks, great soution there.
Have autocorrection in Norwegian om mye phone, SOS suspect befolkes suspekt ???
Think the autocorrection will be turned PDF, (off), never liked it, came om after reinstall.
Caprimaniac
Post by Caprimaniac » Sun May 08, 2016 9:31 am
Hope somone can answer this...
In the Camaro forums I found a thread on this subject.
It was said that the FORD T-5 shifter does share two of the bolt holes With the GM T5.
You can use a FORD T-5 shifter on a GM T-5 by simply drilling two New holes.... IS THIS TRUE?
I was going With a Hurst shifter for the Camaro, but unfortunately, it is no longer available....
Thanks
RS
ChevyEFI
Post by ChevyEFI » Sun May 08, 2016 4:35 pm
Core Shifters offers a new Camaro T5 shifter base.
Yes, if the 4-bolt hole pattern is added to the Mustang shifter, it could work.
Caprimaniac
Post by Caprimaniac » Sat May 14, 2016 5:53 pm
Thanks, Chev.
Yes, I think I have seen "Core shifters" on ebay, so it's a Company? I thought it was the name of what was done to the shifters.
I searched ebay at a later time and couldn't find them then.
I will try using a Mustang T-5 shifter.
Thanks again
Caprimaniac
UPDATE! Re: Short shift Camaro V6 T-5
Post by Caprimaniac » Mon Sep 05, 2016 4:16 pm
Just got the Ford T-5 shifter installed, completely...
First off: The rear holes fit. However, I figured they were off by 1/8 - 1/16" and elongated the holes some.
Holes in the front drilled, but as usual I didn't have the right Tools at hand and holes were off... 1/2 hour extra work,
This Works 100%, so thanks for the tip.
I kept the length of the top plate unchanged, which meant I had to cut a larger hole in the gear tunnel. (Figured that out as every turning & quenching sound in the gearboxgot transmitted to the body as top plate hit the tunnel.... You probably know what I mean...)
Kept it like that since I have 2 other Ford T-5's, and you never know if you need a quickshift....
