9" FORD THRU BOLT LEAK
Transmission to Rear-end
598 BIG RAT
Post by 598 BIG RAT » Sun Jul 26, 2015 1:08 pm
HELLO GENTS
My third member is leaking at the bottom thru bolt. Since i have never dismantled a thru bolt third member i thought i would ask someone who knows.
can i just take it out and put a new washer on it or what would you guys do?
Supershafts
Re: 9" FORD THRU BOLT LEAK
Post by Supershafts » Sun Jul 26, 2015 3:54 pm
You could remove it and replace the washer
We Race, We Vote!! Limotorsports.org
Supershafts.com
598 BIG RAT
Post by 598 BIG RAT » Mon Jul 27, 2015 1:13 pm
i didn't know if i could just take the bolt out without taking the internals apart or not.
THANK YOU
R.C.
Supershafts
Post by Supershafts » Tue Jul 28, 2015 9:53 pm
You'll have to drop the center, it may be loose. I have never had one leak before
Supershafts.com
Straight Shooter
Post by Straight Shooter » Sun Aug 23, 2015 6:33 pm
There is a nut on the other end of the bolt holding the bearing cap on. The third member must be removed to remove the nut. A little silicone on each bolt head and washer will keep it from leaking. Simply changing the hardened washer most likely not stop a leak.
598 BIG RAT
Post by 598 BIG RAT » Wed May 25, 2016 7:14 pm
Straight Shooter wrote:There is a nut on the other end of the bolt holding the bearing cap on. The third member must be removed to remove the nut. A little silicone on each bolt head and washer will keep it from leaking. Simply changing the hardened washer most likely not stop a leak.
i got the problem resolved thanks for your help!
598 BIG RAT
Post by 598 BIG RAT » Wed May 25, 2016 7:16 pm
Supershafts wrote:You'll have to drop the center, it may be loose. I have never had one leak before
We went thru it .
Thanks
