200 4r tv limit valve spring
Transmission to Rear-end
cowman
Post by cowman » Wed Sep 30, 2015 4:01 am
http://www.montecarloss.com/community/u ... ber=579874
This maybe a longshot but I am trying to find this spring. There is a diagram of the VB in the link, the spring is on the right side of the pic just above the throttle valve. I believe GM used 2 different springs in there, but the spring dimensions in the diagram is the one I need. If anyone knows of junked trans or VBs I would be grateful.
ChevyEFI
Re: 200 4r tv limit valve spring
Post by ChevyEFI » Wed Oct 07, 2015 11:39 pm
Get as close as you can, erring a little bit stiffer if anything.
You're more likely to find 0.035" wire than 0.033".
Measure; see if the a 0.375" o.d. will work. Again because of common availability.
It's WOT shifts, but balances forces with the gov., so it won't ruin everything if you're off a touch.
cowman
Post by cowman » Sat Oct 10, 2015 2:56 am
Thanks for the reply, it looks like we have found one and it is on the way.
