drilled th350 plate question
Transmission to Rear-end
mdabbott2009
Post by mdabbott2009 » Sat Nov 07, 2015 8:19 pm
Can anyone tell which passages are drilled ind why my book doesn't show this and I'm very curioue
Greenlight
Re: drilled th350 plate question
Post by Greenlight » Mon Nov 16, 2015 10:05 pm
Drill the hole labeled 2nd to .125" (1/8"). Drill the hole labeled 3rd to .125-.140"
Optional is to remove the spring from the 2-3 accumulator in the valve body and then install a 3/8 nut on top of the piston, then a washer, then the e-clip.
http://www.hotrodders.com/forum/t-350-r ... 45361.html
Project Greenlight
