Fabricate piece to adapt th350 to C4 corvette C beam
Transmission to Rear-end
85stroker
Post by 85stroker » Thu Nov 19, 2015 9:02 pm
Trying to find a fabricator who has or can make adapter to install a th350 or a glide in a c4 corvette.
This allows the transmission to bolt up to the C-beam.
I have found pictures but not who made it - Any assistance with this will be appreciated.
Thanks for looking
http://s8.photobucket.com/user/vet85us/ ... sort=4&o=4
ChevyEFI
Re: Fabricate piece to adapt th350 to C4 corvette C beam
Post by ChevyEFI » Fri Nov 27, 2015 10:51 am
Bolt a C4 Corvette extension housing onto the TH350. Same bolt pattern; close to the same length.
If you use a 9" long tail TH350 or a 700-R4 output shaft with fitzall switch kit spacer it will let you run the same driveline.
85stroker
Post by 85stroker » Sat Nov 28, 2015 9:52 am
ChevyEFI wrote:Bolt a C4 Corvette extension housing onto the TH350. Same bolt pattern; close to the same length.
Thanks for the info.
Sorry I should have clarified that I am going with a glide and this will not work.
