wheel nut torque
Transmission to Rear-end
steve cowan
wheel nut torque
Post by steve cowan » Wed Dec 02, 2015 4:48 am
hi guys,i just purchased a new set of weld draglites and looking for a torque setting,1/2 inch stud 255 drag radial street/strip 3400 pound utility,i figured 100 ft/pounds with torque wrench but not 100 % certain thanks for any feedback
steve c
dave brode
Re: wheel nut torque
Post by dave brode » Wed Dec 02, 2015 8:45 am
steve cowan wrote:hi guys,i just purchased a new set of weld draglites and looking for a torque setting,1/2 inch stud 255 drag radial street/strip 3400 pound utility,i figured 100 ft/pounds with torque wrench but not 100 % certain thanks for any feedback
Steve,
I went 65 on forged alum shank style lugs as well as tapered lugs for alum and normal steel rims for year and years w/o issue until I read of guys using much more. I now use 80. I always use anti-seize on the threads and also use grease under the washers and around the shanks. The soft forged weld rims will tent to gall there even with it.
Dave
Dan Timberlake
Post by Dan Timberlake » Wed Dec 02, 2015 3:54 pm
http://weldwheels.com/faqs/
"7/16 Wheel stud = 75-85 ft-lbs
1/2 Wheel stud = 85-95 ft-lbs
5/8 Wheel stud = 130-140 ft-lbs
12mm = 90 ft-lbs 14mm = 110 ft-lbs
Weld Racing does not recommend the use of lubricant when installing lug nuts. "
A post from 2002 on
http://ls1tech.com/forums/drag-racing-t ... heels.html
says this -
"According to my sheet and sticker that came with my Draglites:
LUG NUTS-Torque specs.in ft.lbs 7/16"=55-65,1/2"=80-90,9/16=120,12mm=70-80,14mm=85-90,5/8=135-145"
Retorque at 25 miles and 100 mile intervals until torque is maintained.
dave brode
Post by dave brode » Wed Dec 02, 2015 6:37 pm
Dan/Steve,
I should have started out "fwiw'".
They say: Weld Racing does not recommend the use of lubricant when installing lug nuts. "
I say: esp if you R&R your wheel/tires fairly often, you will wish you had if you don't. The shanks will tear at the rims, as will the washers.
I never had issues even well lubed at 65 lbs .
Dave
Dan Timberlake
Post by Dan Timberlake » Wed Dec 02, 2015 11:35 pm
dave brode wrote:Dan/Steve,
Dave
Hi Dave,
I lube my lugs also. And the hub and wheel pilots.
I live in salty Massachusetts.
One time in winter I had to play a 50,000 BTU kerosene heater on the alloy wheels to enlarge them and release it's corroded grip on the hub.
dave brode
Post by dave brode » Thu Dec 03, 2015 7:20 am
Hi Dan,
LOL. Been there too. I do same, antiseeze on hub, threads and taper.
Dave
autogear
Post by autogear » Thu Dec 03, 2015 1:36 pm
I live in "The Salt City" Syracuse NY...everything gets Anti-Seize, and any polished aluminum gets a coat of wax or SharkHyde
I had a customer cave in a weld wheel on a pothole here, so be careful (but my old convo pros were ok?)
steve cowan
Post by steve cowan » Fri Dec 04, 2015 6:36 pm
thanks for the replies guys,i bought weld lug nuts and washers which seem to slightly concave so they may help relieve galling (maybe) personally i am not a fan of antisieze because of its flinging action when gets hot,where i am here in brisbane,australia the conditions are similar to california,these wheels will probaly be on and off more times than a brides nighty as i have a few wheel combos-anyway thanks again :D
steve c
clshore
Post by clshore » Mon Jan 04, 2016 4:26 pm
Sounds like you need Drislide then.
