Larger trans cooler lines
Transmission to Rear-end
BOOT
Post by BOOT » Sun Jan 03, 2016 7:10 am
Do you drill and tap the case for larger fittings for the larger lines?
Coloradoracer
Re: Larger trans cooler lines
Post by Coloradoracer » Sun Jan 03, 2016 10:28 am
No. Just install appropriate fittings if they are AN style. What you're doing basically is adding fluid volume to the trans and cooling circuit.....
Mark Goulette
Authorized Amsoil Retailer
