Saginaw trans gear material
Transmission to Rear-end
joespanova
Post by joespanova » Mon Feb 15, 2016 7:47 pm
Can anyone confirm if the Saginaw trans gears are 8620 steel...........or?
I'm going to weld a cluster.
modified wanna be
BigBlocksOnTop2
Re: Saginaw trans gear material
Post by BigBlocksOnTop2 » Tue Feb 16, 2016 2:20 pm
Don't know about your welding rod but look at Eutectic Xuper 680 rod. From what I understand, if it's steel based this rod will weld it. They are $$$.
autogear
Post by autogear » Thu Feb 18, 2016 9:19 am
Were GM 'Saginaw' gears cut from SAE 8620 steel? Probably. There is almost a century of automotive experience with the alloy, and it is the first choice in North America. That said, given that GM bought steel in mill runs, they *could* have used something else if it worked and saved money --- New Process and Warner Gear sometimes did this. My guess is that, whatever it was, it probably welds about the same.
Hope it helps.
George E Sollish
Chief Engineer
Auto Gear Company
