Convert Cuckoo clock (Gov lock) to regular posi
Transmission to Rear-end
GLHS60
Post by GLHS60 » Sat Apr 16, 2016 2:51 am
Anyone ever converted a GM Gov lock to a regular posi??
A local guy did some years ago, he removed all the Gov lock parts and used a factory S spring instead.
He also welded the "ramp" on the axle gear that normally gets wound up to lock it.
I recently did a search on converting one and the only thing I found was a guy who did the same thing but he didn't weld the ramp.
Curious if anyone else ever converted one and if they welded the "ramp" or not.
Thanks
Sherwood Park
Alberta,Canada
Coloradoracer
Re: Convert Cuckoo clock (Gov lock) to regular posi
Post by Coloradoracer » Sat Apr 16, 2016 9:36 am
I'd just replace it with a posi. Personally, it's a waste of time to try and "convert" it, and having to source the parts, modify, etc.....
Not worth the trouble......
Mark Goulette
Authorized Amsoil Retailer
peejay
Post by peejay » Sat Apr 16, 2016 10:23 am
I wouldn't bother either. The case itself is pretty weak. They seem to break the cases before they wear out. I've even seen them in perfectly driving trucks with chunks broken out of the case and large longitudinal cracks forming but not broken all the way around yet. That's a nice how-do-you-do when you just have the cover popped off for the annual fluid change.
Do it once, do it right.
GLHS60
Post by GLHS60 » Sat Apr 16, 2016 4:41 pm
I appreciate your replies but it's just something I have to try, I already have the gov lock and S spring so no $$ is needed. I'm old and feeble, Just trying to determine if the ramp welding or not is an issue.
Thanks
Sherwood Park
Alberta,Canada
Coloradoracer
Post by Coloradoracer » Sun Apr 17, 2016 11:47 am
As a word of advice, that case will likely break under use, and welding on it will make it weaker. Honestly, if it were mine, I'd just run it until I can get it done right by replacing it....You'll be money ahead...
Mark Goulette
GLHS60
Post by GLHS60 » Sun Apr 17, 2016 12:23 pm
It's just the ramp on the axle gear that gets welded if any welding is done at all.
Just trying to figure out if it even needs welding and the reason behind it.
Surely the ramp won't even work with no wind up mechanism ??
Its only a low power street car running 75 series tires.
Thanks
Sherwood Park
Alberta,Canada
