Driveline losses
Transmission to Rear-end
cstepro
Driveline losses
Post by cstepro » Wed Apr 27, 2016 5:24 pm
Anyone have any ideas for lessening driveline powerloss?
Dan Timberlake
Re: Driveline losses
Post by Dan Timberlake » Thu Apr 28, 2016 2:36 pm
drag racing, mild mannered street use, or ???
what kind of transmission?
cstepro
Post by cstepro » Thu Apr 28, 2016 3:37 pm
PS4 pulling truck, single speed transmisson, profab drop box (spur gears), rockwell f106 rear, dana 60 front
BOOT
Post by BOOT » Tue May 03, 2016 9:37 am
U-joint angle is one
Coloradoracer
Post by Coloradoracer » Sun May 08, 2016 10:25 am
Lightened ring gears, REM polishing, light bearing preload, thinnest possible diff fluid you can safely run
Mark Goulette
Authorized Amsoil Retailer
cstepro
Post by cstepro » Sun May 08, 2016 8:32 pm
Do you have any experience with lighter "gear" oil? I know so guys have seen a bump from using engine or trans fluid but there gears ended up scuffing. I've heard of a Gibbs zero weight?
What about a dry sump on a axle?
Coloradoracer
Post by Coloradoracer » Sun May 08, 2016 9:22 pm
Whatever gear oil you use needs to be capable of providing the shock loading protection that the oil is designed for. When I say the thinnest possible you can SAFELY use, I'm not talking about 0 weight engine oil. I'm thinking more along the lines of 50 wt gear oil, provided it can still provide not only the proper lubrication it needs too but also shock loading, heat, scuffing protection, etc... An example would be someone going to a straight 75wt instead of running a 140 wt....... I'd never run engine oil in a diff as its not formulated to provide the protection the gears need. Two different animals altogether.
Mark Goulette
De Haan Motorsport
Post by De Haan Motorsport » Tue May 17, 2016 1:23 pm
Is there somebody over here who has experience with ceramic bearings in a gearbox?
jacksoni
Post by jacksoni » Fri Sep 02, 2016 5:01 pm
What about things like the Red Line Lightweight and super lightweight Shockproof gear oils?
https://www.redlineoil.com/Products.aspx?pcid=8
