Hey guys, I'm rebuilding a 3sp Saginaw and trying currently trying to remove 1st speed gear. I CANNOT get this thing off. The rear bearing and 1st sync rings pressed off easy. 1st gear started coming off and move about 1/2" but will not budge after that..
Please help!
Saginaw 3 speed rebuild help!
- New Member
Re: Saginaw 3 speed rebuild help!
Since it's a Saginaw, grip just under the gear and put your other hand on the pilot end.
Hammer the output end against a piece of wood on the floor.
Or get a proper puller / press.
I do have a proper press equipped with a 12 ton jack.. I figure it should be plenty to press these gears off...ChevyEFI wrote:Since it's a Saginaw, grip just under the gear and put your other hand on the pilot end.
I started from the tailshaft end and removed the reverse gear and syncro assembly. I proceeded to attempt removing 1st gear with no luck. It moved about 1/2" and then stopped dead. I applied a little heat and it moved about 1/2" farther.. Then stopped.. I'm lost as to what could be keeping it from coming off? Is there a snap ring holding 1st gear in place besides the syncro snap ring? My diagram showed nothing....
sounds like you either welded 1st gear up on the mainshaft or are pretty close to it. This happens when you spend a lot of time in the upper gears, like circle track racing.
Mike @ Magnus Racing in Danielson, CT is one of the premier circle track Saginaw builders and may have an answer to preventing this in the future. He will also have a selection of gears and shafts for you.
