Heating trans or diff before a run
Transmission to Rear-end
jacksoni
Post by jacksoni » Mon Aug 29, 2016 8:28 am
Is there any value in heating the oil in transmission and/or differential before a run (drag, road race, lsr)? I think Nascar may for qualifying? How hot?
Adger Smith
Re: Heating trans or diff before a run
Post by Adger Smith » Thu Sep 01, 2016 7:02 am
A sprag in a converter will sometimes respond to heated fluid.
Found this out on a bracket car that would not run consistent numbers & was not predictable.
It ran all over the place after cool down between rounds and between warm afternoon and cooler nights .
Went to a spragless converter and it would print numbers.
A lot of Comp racers heat the fluids.
If there was nothing there would they do it?
Be careful to heat, not boil.
Adger Smith
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
jacksoni
Post by jacksoni » Fri Sep 02, 2016 8:08 am
Thanks, Adger. This past Bonneville I was running within .5mph of the record (sometimes over, sometimes under) and we are looking for any little bit to help. I am going to try this as well, perhaps, some superlight weight oils (that hopefully will still protect things.)
