How much carrier bearing preload
Transmission to Rear-end
Bob Hollinshead
Post by Bob Hollinshead » Mon Sep 12, 2016 7:57 am
GM 9.5" 14 bolt rear differential, This has the adjuster on the right side of the housing. How do I know where to set this adjustment? Bring the adjuster in for a snug fit then how much more?
Pro question poster.
Bob Hollinshead
Re: How much carrier bearing preload
Post by Bob Hollinshead » Wed Sep 14, 2016 9:27 am
35 views and no comments LOL, I could spread the case .010 I guess and run the adjuster up snug? But there must be some easy rule to go by
BigBlocksOnTop2
Post by BigBlocksOnTop2 » Wed Sep 14, 2016 9:06 pm
I have done a 9'' for myself with the same bearings (used). I set the pinion at 12 inch pounds (the amount of torque to keep rotation). Then I set the carrier preload until I recorded 24 inch pounds, rotating the pinion. Twelve in.lbs. for the pinion and 12 in. lbs. for the carrier. These same numbers would work for you to. The reason why I reset my diff. is because it was set up for circle track racing and it was loose. It was an E-Bay purchase.
Bob Hollinshead
Post by Bob Hollinshead » Wed Sep 14, 2016 10:10 pm
with used bearings 24" lbs. might be right? maybe 30% more with new bearings? I read one writeup that suggested moving the right side adjuster three notches past snug.
peejay
Post by peejay » Thu Sep 15, 2016 8:28 pm
On 9" I haven't had problems with going two adjuster holes tighter than just barely snug. Not sure if that's too loose or too tight but it hasn't failed me yet.
Bob Hollinshead
Post by Bob Hollinshead » Fri Sep 16, 2016 1:10 am
good to know!
Dan Timberlake
Post by Dan Timberlake » Sat Sep 17, 2016 9:42 am
http://www.pirate4x4.com/tech/billavist ... le/14b.pdf
On page 6-101 This also suggests 2 notches tight with used bearings and 3 notches tight for new bearings.
Reportedly gleaned from factory and military manuals.
peejay
Post by peejay » Sun Sep 18, 2016 8:16 pm
Good to know! Now I don't feel too bad about the ones where I went three holes out when I was trying to get backlash just right and didn't want to back off the other side...
