700r4 shift
Transmission to Rear-end
BOOT
700r4 shift
Post by BOOT » Sun Oct 30, 2016 2:06 pm
Ok I've know there is the corvette servo and a shift kit of course but recently read something bout a accumulator valve kit? Is that something included in the Tran go kit or separate? If not would you use all 3 together?
Greenlight
Re: 700r4 shift
Post by Greenlight » Sat Nov 12, 2016 1:44 am
Sonnax will have any of the parts you need:
http://www.sonnax.com/units/213-4L60
Project Greenlight
Pro Built Automatics
Re: 700r4 shift
Post by Pro Built Automatics » Sun Jan 29, 2017 6:21 am
When using the TransGo Junior Shift Kit, the "A" or "B" accumulator valve in the valve body will work best with the over and under 2nd accumulator spring setup that TransGo uses here. The "M" or "L" accumulator valve works best with the under accumulator spring that the factory uses. Spend the money on the Shift kit instead of the Sonnax accumulator valve kit, you will get much more out of it. This kit can be made into a Heavy Duty Shift kit easily. Add the Corvette servo, .471" main boost valve, .296" intermediate/reverse boost valve and my modified Shift kit instructions.
