3 speed or glide
Transmission to Rear-end
phantomfab
3 speed or glide
Post by phantomfab » Mon Feb 13, 2017 4:04 am
Hey guys. Putting together a bmod and was wondering which one would be better: a direst drive powerglide or a 3 spreed saginaw with a 16 lbs flywheel and a 20 lbs clutch. Flexplate for the glide is around 8 lbs. and im not sure about the drive. Which one is going to give less problems, I'm open to peoples opinions. Also, does anyone know the rotating weights for these transmissions? Thanks in advance.
barnym17
Re: 3 speed or glide
Post by barnym17 » Tue Feb 14, 2017 6:08 am
from years of experience a glide with a coupler will walk off and leave a 3 speed with a stock size flywheel and pressure plate.With a triple disc the difference is still there but not as great.
ZIGGY
Post by ZIGGY » Tue Feb 14, 2017 8:31 am
X2
phantomfab
Post by phantomfab » Wed Feb 15, 2017 8:36 am
barnym17 wrote:from years of experience a glide with a coupler will walk off and leave a 3 speed with a stock size flywheel and pressure plate.With a triple disc the difference is still there but not as great.
I appreciate the reply, did you have any problems running the glide? Failures, issues, etc. Maintenance hassle?
