Page 1 of 1
dana rear
Posted: Sun Mar 05, 2017 8:46 pm
by redgoldstein
moser or strange dana witch is the better of the two taking out a 8/34 mopar stk elm car thanks
Re: dana rear
Posted: Thu Mar 09, 2017 4:33 pm
by Ron E
I don't think you'll see any difference. Comes down to better deal..That, and seeing you're running a stocker, if one has lighter moving parts than the other.
Re: dana rear
Posted: Wed Apr 26, 2017 7:24 pm
by Jeff Lee
Make sure you get the CM axle tubes. I’ve had my MW Dana 60 in my AMX since I built it in 1998. Used in both Stock & Super Stock, always a 4-speed, and some years with brutal clutches (meaning WAY TOO MUCH!) and never changed a gear set that didn’t look as good as when I put it in. I have MW light-weight steel spool and billet main cap, MW 40-spline Gun-drilled axles. All circa 1998. Calvert makes CM perches for $100 a pair.
