Page 1 of 1
Powerglide planetary help
Posted: Tue Oct 03, 2017 1:08 am
by cgarb
I have a TCI planetary that was a 1.89 helical cut gearset. It's an aftermarket housing with bolt in pins, the heavy duty type. It chipped a tooth off one of the gears and made a bunch of loud noises...lol. It was not happy. Question for some trans builders...Can I take that housing and order a set of 1.80 straight cut gears, new sun gear, ring gear and a shim and needle bearing kit and use the housing over? It had some gall marks on the outside of the housing where the pieces were forced though, no damage to any of the machined faces or critical areas that I can see.
Re: Powerglide planetary help
Posted: Tue Oct 03, 2017 3:23 pm
by fdicrasto
I would question whether the cost of purchasing the parts separately would be a whole lot cheaper than buying the complete set up and not having to re use the damaged housing. Just a thought.
Posted: Tue Oct 03, 2017 4:37 pm
by cgarb
Yes, I'm buying a new one for in my good case, was going to try and fix this one to put in a stock case for a spare trans.
Posted: Sat Oct 07, 2017 11:37 am
by Coloradoracer
Honestly, for the cost of the new parts, you're still money ahead for just getting a whole new gearset with carrier.....
Posted: Fri Apr 06, 2018 5:59 am
by cgarb
Just finished assembling my brand new 1.87 gearset glide in a brand new ATI case. I don't think the need for a spare is going to be super urgent now.
