turbo 400 vs powerglide
Transmission to Rear-end
guest
Post by guest » Tue Dec 28, 2004 2:10 pm
which trans would be faster 400 or powerglide in a 3400 lb car with 950 hp thanks
Guest
Post by Guest » Sun Jan 02, 2005 10:27 pm
Technically the PG should be quicker in a drag only application at that power level and weight - provided the converter and chassis setup is right. On a bang for the buck basis the TH wins hands down. Why not do the TH and spend the difference on some more weight dropping changes?
Thomas
Guest
Post by Guest » Mon Jan 03, 2005 10:13 pm
I have about 950hp on spray..i run a turbo 400 i think its pretty quick..i think the 400 would be faster and the p/g would be more consistent...my 02 :D
Floyd
Post by Floyd » Thu Feb 03, 2005 8:35 pm
I would pick a TH400 over the Glide in that heavy of an application. If you see any street time at all it's going to be a pain to get it going with a glide.
However if you're a bracket racer it's hard to argue or beat a glide.
oldhead
Post by oldhead » Tue Aug 23, 2005 5:21 pm
My freind 78 Malibu,3100 lbs,948 hp. with nitrous 1474 hp. He was braking 400's, put in a PG. with the same conv..................SAME TIMES,et. mph, 60 ft.8.30 at 163 mph................400 had low firstgear.....OLDHEAD :D :D :D :D
Quicker then most
SupStk
Post by SupStk » Wed Sep 07, 2005 7:39 pm
A racing buddy called his converter guy and was told, "Anything under 3,ooo# to use a glide over that a 350 or 400 would be quicker". If I remember right his 3600 lb SBC Chevelle was .02 quicker with the 400. In this case i would consider it a wash. In my opinion a high torgue engine may not need the low gear of the turbo.
