My hot tank is getting an oil film on top of the water...how should a guy go about soaking this up, a PIG mat?
Should you shut the heater off to let the oil come to the top?
Removing oil from hot tank
You can buy a device called a "tramp oil skimmer" that's essentially a motor-driven belt. One end goes down into the tank, and part of it hangs off the side, where a blade scrapes any oil off and sends it down a guide to a catch can.
You can blot the oil up with shop rags, paper towels, or old newspapers if you're not in a hurry.
hot tank
I just did the newspaper deal to my hot tank last week and it worked great...
I did look at the Pig mats, but as long as the newspaper works,,why bother.
Keith
Keith
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
about 2 monthes ago someone had mentioned newspaper on here, i tryed it, and it works great. i agree with doing it with the heat on.FloydODB wrote:newspaper. leave the heat on. lay a sheet of the paper on the oil. and as soon as you do, the oil will stick to the paper. Promptly fold and lift the paper and throw it in a bucket. Repeat.
SAM-MISSLE
SOUTHERN AUTO MACHINE
931-728-7800
931-728-7800
Re: Removing oil from hot tank
Was digging thru old posts and saw this- just spent half the day trying to clean my tank again. Fun. Also found the hole the size of a dime in the line from the pump to the manifold that has reduced my cleaning abilites of late and caused a few foamovers-
Anybody every tried rigging up an external pump and filter system? Think it would work?
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
CPMotorworks,Inc.
