Seting timing on a 350 chev should i just do total advance?
I built a 350 for a suburban with an rv type cam and a performer intake & 9-1 comp The distributor is a vac advance stock gm unit.Should i set the total advance around 35-36 deg. with the vac hose on?? I checked what its at now and its only around 6deg at idle and with the vac hose off i think it was around 25 deg. total and with the vac hose on it was 35 total is this the correct way to set it with the vac hose on? I don't want to give it to much timing & when you loads his 6000# trailer on and it could start pinging
- jmarkaudio
