Hello,
I have a Qwikdata advanced drag racing data acquisition system I've been using for a while. I purchased a travel sensor for the rear suspension from Edelbrock and they provided no specific information about how to integrate it into the existing wiring harness. Has anyone wired one of these? I've tried calling/emailing Edelbrock, but never got a call back or response of any kind. Any advise would be appreciated.
Edelbrock Qwikdata wiring question
- New Member
The easiest way is to use an existing pressure sensor input.
So if you have Oil Pressure on channel 6 plug the sensor into that plug. Then go into Analog Setup and change channel 6 to the shock sensor with 0 volts and 5 volts on the top row and 0 and 8 (8 inch travel sensor?).
then when the car is not moving maybe it shows 4 in travel and movement goes up and down from there. there is a way to make it zero not moving and - + each way but I don't have that written down.
call or e-mail with questions.
609-265-2110 gkelley@motorsportsinnoavtions.com
