kse tandem power steer issues
2xmod
Post by 2xmod » Thu Jun 04, 2009 11:25 pm
I have an IMCA mod ified with a kse tandem pump. The power steering is working well. iT STEERS HARD. i CHANGES THE STEER BOX, AND THE SAME THING HAPPENS. It worked perfect the last race. When loading it on the trailer, I noticed something wasnt right.Any ideas gents???????? Brad
ZIGGY
Re: kse tandem power steer issues
Post by ZIGGY » Mon Feb 13, 2012 11:03 am
2xmod wrote:I have an IMCA mod ified with a kse tandem pump. The power steering is working well. iT STEERS HARD. i CHANGES THE STEER BOX, AND THE SAME THING HAPPENS. It worked perfect the last race. When loading it on the trailer, I noticed something wasnt right.Any ideas gents???????? Brad
Got pressure where the hi-press. line connects to the box? Fluid level good, not foaming? If okay, and you've changed boxes, sounds like something is bent/bound/broke. Jack it up and check the steering linkage.
ZIGGY
Post by ZIGGY » Mon Feb 13, 2012 6:43 pm
P.S. - there is an internal pressure relief valve.
