Aluminum Driveshaft question
Dave Koehler
Post by Dave Koehler » Wed Jul 22, 2009 5:28 pm
1:Does anyone know what the glue is that holds balance weights on an aluminum driveshaft?
2: Where to buy it?
Thanks
Dave Koehler
Re: Aluminum Driveshaft question
Post by Dave Koehler » Thu Dec 11, 2014 9:15 am
bump it up.
Kevin Johnson
Post by Kevin Johnson » Fri Dec 12, 2014 5:51 am
First, contact 3M or Henkel as either may have an off-the-shelf solution that is not ensnarled in a proprietary formulation situation. Many other adhesive manufacturers as well.
Some (many others) patent references:
Epoxy resin, zinc or barium sulfate, polyamide:
http://www.google.com/patents/US3939020
Epichlorohydrin-bisphenol a epoxy resin, inorganic fibrous material, powdered zinc or barium sulfate, polyamide and a catalyst:
http://www.google.com/patents/US4083735
A balance weight and a method of balancing rotary shafts:
http://www.google.com/patents/EP0015640A1?cl=en
At the time that the original patent was written, UV cured products were becoming very popular in the dental field:
http://www.google.com/patents/US4998448
Using liquid epoxy resin; curing:
http://www.google.com/patents/US5201248
Methods for dynamic balancing:
http://www.google.com/patents/US6171418
DANA patent for welding the weights on (in another they spot weld):
http://www.google.com/patents/US5778737
Post by MadBill » Sun Jan 04, 2015 10:42 pm
Dave Koehler wrote:1:Does anyone know what the glue is that holds balance weights on an aluminum driveshaft?
2: Where to buy it?
Thanks
The stuff they used on the aluminum shaft for our T 600-equipped (0.82:1 5th) road racer (9700 shaft RPM @ 185 MPH) appeared to have been recycled bubblegum, judging by the hole the balance weight made in the tin work alongside the driver's thigh... :shock: We took our chances re warpage with 3 spots of weld on the replacement. So far (2 seasons) so good. The balance shop had never maxed one out at 10,000 RPM before. They rigged a remote control and cleared out the shop for the occasion, but all went well.
justahoby
Location: Temporarily in Stephenville, Texas, USA from Thunder Bay, Canada
Post by justahoby » Tue Jan 20, 2015 10:58 pm
I heard the same epoxy they used on trunk panels of gm cars in the 80s is the same as the epoxy used to hold rebar in holes drilled in concrete.. Maybe ?? I dunno.. I did try it long time ago and glued a rocker panel in , it held for years, cut them off to put on another truck after a little clean up :mrgreen: this time welded...lol
I'm assuming this is the epoxy they use it has the " bubble gum wad" look
As I'm approaching 40,I still think I'm 20. What the hell is wrong with me?
Post by MadBill » Tue Jan 20, 2015 11:04 pm
justahoby wrote:I heard the same epoxy they used on trunk panels of gm cars in the 80s is the same as the epoxy used to hold rebar in holes drilled in concrete.. Maybe ?? I dunno.. I did try it long time ago and glued a rocker panel in , it held for years, cut them off to put on another truck after a little clean up :mrgreen: this time welded...lol
I was speaking of the tensile strength, not the appearance... :(
justahoby
Post by justahoby » Tue Jan 20, 2015 11:12 pm
Oh.. Lol makes sense now. Yea.. Body panels don't spin at 10,000 rpm :lol:
Kevin Johnson
Post by Kevin Johnson » Wed Jan 21, 2015 5:37 am
justahoby wrote: I'm assuming this is the epoxy they use it has the " bubble gum wad" look
Hūsker Dū?
General Graycliffe: A child with a stick of chewing gum has just rendered your hundred million dollars of hardware useless.
:lol:
