Carbon Fiber Brake Rotor Material
erikasha
Re: Carbon Fiber Brake Rotor Material
Post by erikasha » Mon Jul 04, 2011 6:00 am
thanks Robson for this info. :)
clshore
Post by clshore » Mon Jul 04, 2011 9:32 am
Found the link I mentioned in earlier post:
http://www.graphitestore.com/index.asp
Lot's of interesting stuff there, the pyrolitic graphite is likely what you need, but as expected, not cheap.
Carter
jsgarage
Post by jsgarage » Wed Nov 16, 2011 1:07 am
As others have said, bring lots of money to a carbon-carbon brake installation, whether you manage to build or buy. Keep in mind that with carbon-carbon, the rotors wear at the same rate as the pads. So you'll be needing far more than one set per corner per year. Pro race teams don't change carbon pads- they change the rotor, the pad and- due to the heat, probably rebuild the caliper- after each session. Too rich for my blood.
jsgarage
Post by jsgarage » Tue Dec 06, 2011 1:29 am
Bob, its been awhile since you posted, but I ran across a reference to metal-matrix brake rotors used in Superbikes (illegal in some classes). The stuff is an aerospace development originally for military jet exhaust shielding. I've held pro racecar rotors made of metal-matrix and you'd swear it was made of nothing at all!
Browse to <www.braketech.com> in Lake Elsinore, CA. and go to Axis/CNC rotors. The bike rotors they're making are still nosebleed-expensive ($1200 for a pair of unvented 11-1/2"OD), but they may be willing to supply you with stock for your experiments.
Ledon Racing
Post by Ledon Racing » Wed Dec 28, 2011 11:32 am
It needn't cost mega money for a carbon brake set up, I buy and sell used & new ex F1 parts and have carbon rotors and pads available that have plenty of life left in them still....
Nathan
mbrooks
Post by mbrooks » Wed Dec 28, 2011 7:25 pm
Ledon Racing wrote:It needn't cost mega money for a carbon brake set up, I buy and sell used & new ex F1 parts and have carbon rotors and pads available that have plenty of life left in them still....
Nathan
so what does it cost to save 40# of rotating weight?
Ledon Racing
Post by Ledon Racing » Sat Jan 28, 2012 8:17 am
My new vented carbon rotors are $199 a pair.
I have good condition used carbon pads for $120 for a set of 4.
Also have good condition used rotors for $120 a pair.
mbrooks
Post by mbrooks » Sat Jan 28, 2012 11:38 am
Ledon Racing wrote:My new vented carbon rotors are $199 a pair.
that would be a sweet deal if they were bolt on!
rb0804
Post by rb0804 » Sun Jan 13, 2013 10:50 pm
Are the pads carbon also? Do the companies selling carbon brake kits do any work to the carbon rotors like attaching the inner hub or do they come already put together from the company making the rotors? Thanks.
mbrooks
Post by mbrooks » Mon Jan 14, 2013 8:41 am
wilwood is making a complete set now for '05+ mustangs, probably others also. takes 18" rims though for the fronts on the mustang since they use a 14" disc. $6k+ price for each end.
