toulene
393ci
toulene
Post by 393ci » Wed Jul 21, 2010 6:38 pm
i have a 14.2:1 comp engine and i'm wanting to run it on 98 octane pump fuel and toulene, does anyone know what the mixing % would be to do this safely if it can be done
Thanks
CHT
Re: toulene
Post by CHT » Wed Jul 21, 2010 8:30 pm
Tolulene I have found works well to 10% mix ratio after that it has less effect. I dont think you'll get there though with that comp, unless it's got a very low DCR
shoedoos
Re: toulene
Post by shoedoos » Thu Jul 22, 2010 10:23 pm
Schurkey
Re: toulene
Post by Schurkey » Thu Jul 22, 2010 11:09 pm
393ci wrote:i have a 14.2:1 comp engine and i'm wanting to run it on 98 octane pump fuel and toulene, does anyone know what the mixing % would be to do this safely if it can be done
Thanks
Keep in mind that European "98 octane" fuel is approximately the same as American 92--93 octane fuel.
There's a difference in the rating methods.
David Redszus
Re: toulene
Post by David Redszus » Mon Aug 09, 2010 11:11 pm
Thanks
The best you can do with the pump fuel you have available is to blend it with 40-50% mXylene.
mXylene has the highest MON octane value of any readily available compound. But the actual octane value of the above blend is uncertain since we do not know the nature of the other pump fuel components.
You might also try a splash of ethanol in order to cool the inlet charge and raise vapor pressure.
lyonsperf
Re: toulene
Post by lyonsperf » Thu Aug 26, 2010 7:52 am
Or you can add a methanol/water injection system like Devilsown to eliminate detonation and improve power.
Dealer for Undercover Innovations, Metco,Dynamic,Fragola and many other American Made products!
Check my site http://www.lyonsperformance.com
