Page 1 of 1
sbc exhaust
Posted: Tue Jan 31, 2006 2:25 am
by teamdirt
i will be running a 85 monte witha 305 sbc purestock on a dirt track, i am looking for the best flow exhaust, we can not use center dumps.. any one have some suggestions?? thanks
Posted: Wed Feb 08, 2006 4:01 pm
by Team Owner
Not enough information.
When you are talking 305 and Metric chassis you are pretty much stuck with what you have.
You might try and see if a stock exh manifold off a 1973 - 75 Chevy Truck will fit - depending on clearance of the firewall - if it doesn't one off a 74 - 76 Chevy van . Stay away from the ones that have the ports for the air tubes if possible.
If you have to use the spacer with the flap in it - just cut it out with a cutting torch and plug the hole by tapping a thread and using a bolt or else just weld it shut.
The origioinal Metric ones have a habit of breaking at the studs.
