Early GM obd2 question.
crazyman
Post by crazyman » Sat Oct 23, 2010 1:27 am
The spark retard from the knock sensor. Does it pull it all at once, or is it variable retard based on voltage output?
Thanks.
In-Tech
Re: Early GM obd2 question.
Post by In-Tech » Sun Oct 24, 2010 2:51 pm
crazyman wrote:The spark retard from the knock sensor. Does it pull it all at once, or is it variable retard based on voltage output?
Thanks.
What year/engine? I'll look up the code when you provide the info.
-Carl
In-Tech
Post by In-Tech » Sun Oct 24, 2010 8:53 pm
Here's a screen shot of a '96 Chevy PU Vortech 350 knock attack table. As far as I know, all GM ecm/pcm's have an attack and decay rate. So, to briefly answer your question, it ramps up to gain control and then continually tries to decay it out as long as there is no knock. Hope this helps.
-Carl
crazyman
Post by crazyman » Mon Oct 25, 2010 10:16 pm
Thanks In-Tech!
