Flowing a intake manifold on a flow bench
91daytona
Post by 91daytona » Wed Jan 19, 2011 5:51 pm
Does anyone have pictures or a detailed description of how an intake manifold is mounted on a flow bench for testing?
I assume all the ports besides the one being tested are blocked off.
Can you install a four hole radius plate on the carb base or should it be a open radius plate?
revolutionary
Re: Flowing a intake manifold on a flow bench
Post by revolutionary » Wed Jan 19, 2011 11:18 pm
You can either bolt it to your head or flip it upside down and bolt the carb flange to the bench
Daryl
Revolutionary Performance and Machine
David Redszus
Post by David Redszus » Fri Jan 28, 2011 9:02 pm
Whenever I have bench flowed intake manifolds I have done so with the manifold attached to the head. Block off all other ports or simply leave the valves closed.
91daytona
Post by 91daytona » Mon Jan 31, 2011 12:19 pm
That's how I have been doing it also but I know there will be times that a customers heads will not be available. I will make an adapter and do some testing. thanks.
David Redszus
Post by David Redszus » Sat Feb 05, 2011 1:43 pm
When it comes time to flow the exhaust ports, does anyone attach the exhaust header and pipes?
If not, why not?
Post by 1989TransAm » Sat Feb 05, 2011 11:48 pm
"When it comes time to flow the exhaust ports, does anyone attach the exhaust header and pipes?
If not, why not?"
According to "Exhausted" The first 8" of the header is the most critical part. So if that is the case why not attach a pieced of pipe with say a 90 degree bend with a total length of 8" or so. Seems to me that would be more realistic.
As to flowing intake manifolds on a SF600 one of the guys in our club made an adaptor that bolts on to the flow bench and then shaped to fit on in this case a SBC intake manifold one port at a time. The bolt holes are slotted so that you can adjust for alignment or to fit the adjacent port. Wish I had a picture to show as it is a work of art.
91daytona
Post by 91daytona » Sun Feb 06, 2011 12:03 am
I would like to see a picture of that.
rob vine
Post by rob vine » Sun Feb 06, 2011 11:38 am
years ago flowdata or quadrant scientific had a flow bench that mocked up two heads and an intake on it - i had some liturature on this from an old pri show in cinnci - i wonder if they sold many and how well they performed - curious ,as i would like to know- i think the idea was there and always thought that it would be good for testing intakes
David Redszus
Post by David Redszus » Mon Feb 07, 2011 8:11 am
If a cylinder head is to be tested with the intake (or exhaust) manifold attached, it is wise to remember that the runner volumes from the other cylinders will act as a Hemholz resonator and will "tune" at certain air speeds. And that some of the other valves are open while others are closed. This effect will certainly skew measurements.
Now the question becomes whether or not a flow bench can produce the necessary air velocites, as seen in a running engine, that will accurately replicate the tuning effect of branched pipes.
SAE paper 720214 "Design refinement of induction and exhaust systems using steady-state bench techniques", does a nice job of exploring the branched pipe effects.
