Tapered cartridge rolls
winr
Post by winr » Mon Mar 07, 2011 8:57 pm
I am finishing cleaning up the bowls and ports in my FE heads.
I am leaving the intakes rough but would like to make the exhaust ports and chambers fairly smooth.
I think I need some tapered cartridges to get into the corners of the exhaust ports and chambers.
I see Summit has some 3/4" tapered cartridges that use a 1/8" collet.
Any advice as to what others use ??
Mild .040 over 390 going in a 1965 F-100
C8 heads, forged pistons/.047 quench, Comp 260 H cam, 1 3/4" SS headers.
TIA.
Ricky.
All your Truck are belong to us
Enigma
Re: Tapered cartridge rolls
Post by Enigma » Mon Mar 07, 2011 9:38 pm
I've never used the summit brand, but I do know that the "dr air" kit is of great quality for just a few bucks more. And it contains more than enough rolls for several sets of heads. It can be ordered through dr j's performance. I've even made made own from Emory cloth and Pvc glue in a pinch. Not pretty, but worked great. And thrifty! Best of luck on your build!
winr
Post by winr » Mon Mar 07, 2011 11:20 pm
Thank you Enigma :-)
I will check out "dr air" and maybe try and roll a few of my own :-))
Thanks on the build, I rebuilt the original 352 over 20 years ago but need some more getty up !!
Ricky.
Enigma
Post by Enigma » Tue Mar 08, 2011 10:25 am
You're quite welcome sir. Tip: if you decide to put a few of your own together....you can buy Emory cloth at local craft shops for next to nothing. Cut it into 1 inch wide lengths, apply a thin bit of PVC glue to the center one third of the strip (keeping it away from the edges so it doesn't get hot and leak out into your work) and roll them up to the thickness and taper that you need. Again, not pretty, but very effective for a home job. And cost conscious. Good luck with that classic. Keep it going for another 20 years!
BigBlocksOnTop
Post by BigBlocksOnTop » Wed Mar 16, 2011 1:38 pm
Try McMaster Carr
winr
Post by winr » Wed Mar 16, 2011 11:21 pm
Thank you BigBlocksOnTop :-)
Ricky.
SMITHBERGRACING
Post by SMITHBERGRACING » Thu Mar 17, 2011 12:25 am
Try GOODSON, they have a bunch of different styles and are reasonably priced.
winr
Post by winr » Thu Mar 17, 2011 1:23 am
Thank you SMITHBERGRACING :-)
Ricky.
bill jones
Post by bill jones » Thu Mar 17, 2011 11:29 am
-here's a list of some abrasives (with prices) I have, you might find something there.
-you'll also need mandrels.
http://ryanbrownracing.com/Bill_Jones_Page_18.html
winr
Post by winr » Sat Mar 19, 2011 11:25 pm
Thank you bill.
Going now to check out your site :-)
Ricky.
