Seatbelt install
Len
Seatbelt install
Post by Len »
just got new seat belts and IHRA doesn't allow y type shoulder belts anymore. I was wondering if it is legal to wrap the belts around the cross bar rather than have to weld 2 new tabs??? I would think it would actually be safer as the strap would not have to pass over relatively sharp edges on the mounting clips.
Len
Nwguy
Post by Nwguy »
Current NASCAR( top five divisions) rules require that the shoulder belts be installed by wrapping around a tube rather than being bolted to a tab.
I don't know what IHRA inspectors want to see, maybe give them a call.
Cobra
Post by Cobra »
NHRA requires seatbelts to be securely fastened to the frame, crossmember, or reinforced mounting so that all fittings are in a direct line with the direction of pull. Seatbelts not to be wrapped around lower frame rails.
