Cleaning metalic material off magnets
trex
Post by trex » Fri Nov 25, 2011 12:19 pm
Is there any easy way to get all the metalic powdery stuff off of the magnets around the stainless reusable filter element? This is a PurePower filter I'm using.
DrillDawg
Re: Cleaning metalic material off magnets
Post by DrillDawg » Fri Nov 25, 2011 1:35 pm
wipe it with a rag and then spray with contact cleaner then wipe with clean rag, that should be good enough
BORN RIGHT THE FIRST TIME
trex
Post by trex » Fri Nov 25, 2011 1:53 pm
Yea that's basically what I do. The magnets are set in the convolusions of the stainless filter element and the powder gets pushed into the filter element when trying to clean it out. I guess there just isn't any real easy way to do it.
Kenova
Post by Kenova » Fri Nov 25, 2011 10:53 pm
Plumber's putty.
When I was working on the assembly line our magnetic screw gun tips would get fouled up with metal shavings. We would just jab the screw bit into a blob of putty a couple of times and it would be clear of shavings.
You could use a wad of putty to clear the magnet on your filter.
Ken
Over the hill but still learning!
Retaining it is the hard part.
trex
Post by trex » Fri Nov 25, 2011 11:32 pm
Excellent, the simple solutions are best. Don't know why I didn't think of something like that. Thanks Kenova
