Need to cut flutes / access to a shop with a form ginder
I have an input shaft from a small sports car that we want to vintage race. The input shaft has helical cut gears fixed/made with the input shaft and we need to remove these gears so we can convert to straight cut gears with "dog rings". I can have the gears ground/removed with no problem but cutting the flutes/keyways for the straight cut replacement gear is were the problem lies. The shaft of the gear is hardened/heat treated and the machinists I have talked to tell me that the only machine that will cut the flutes will have to be a form grinder. Could anyone direct me to a shop that could do this work? The input shaft is small and can be boxed and shipped with no problem and I have the straight cut gear that must be fitted to the shaft. There will need to be 6 flutes cut @ 60 degrees from each other. The finished OD of the shaft will need to be 1 Inch. Appreciate any information and input. Jerry
- Baprace
Re: Need to cut flutes / access to a shop with a form ginder
Years ago Doug Nash transmissions cut and welded up some GM clusters for me that worked great in a 9 second Camaro, I don't have a number for him but any drag racing magazine should have his number.
- dfree383
Have you tried Liberty?
Call and talk to Bob Thomas @ Rochester Gear. If they do not have the gear cutting/grinding equiptment he can steer you in the right direction.
213 Norman Street Rochester, NY 14613-1875
(585) 254-5442
(585) 254-5442
