Need to cut flutes / access to a shop with a form ginder
Jerry Poole
Post by Jerry Poole » Sat Dec 03, 2011 10:24 am
I have an input shaft from a small sports car that we want to vintage race. The input shaft has helical cut gears fixed/made with the input shaft and we need to remove these gears so we can convert to straight cut gears with "dog rings". I can have the gears ground/removed with no problem but cutting the flutes/keyways for the straight cut replacement gear is were the problem lies. The shaft of the gear is hardened/heat treated and the machinists I have talked to tell me that the only machine that will cut the flutes will have to be a form grinder. Could anyone direct me to a shop that could do this work? The input shaft is small and can be boxed and shipped with no problem and I have the straight cut gear that must be fitted to the shaft. There will need to be 6 flutes cut @ 60 degrees from each other. The finished OD of the shaft will need to be 1 Inch. Appreciate any information and input. Jerry
Baprace
Re: Need to cut flutes / access to a shop with a form ginder
Post by Baprace » Mon Dec 05, 2011 10:14 pm
Years ago Doug Nash transmissions cut and welded up some GM clusters for me that worked great in a 9 second Camaro, I don't have a number for him but any drag racing magazine should have his number.
dfree383
Post by dfree383 » Tue Dec 06, 2011 2:15 pm
Have you tried Liberty?
uncle paul
Post by uncle paul » Mon Dec 12, 2011 2:49 pm
Call and talk to Bob Thomas @ Rochester Gear. If they do not have the gear cutting/grinding equiptment he can steer you in the right direction.
213 Norman Street Rochester, NY 14613-1875
(585) 254-5442
