work in us
amazonic
work in us
Post by amazonic » Fri Apr 06, 2012 8:25 pm
hi iam from sweden,and i think it would be an big life experience to work in the us.
how hard do you think it is for a swedish guy to get a job and work visa in the us?
I work as a welder and have 111,135,136 certification.
How are the market for welders in us today?
/Jimmy
Keith Morganstein
Re: work in us
Post by Keith Morganstein » Sat Apr 07, 2012 6:07 pm
amazonic wrote:hi iam from sweden,and i think it would be an big life experience to work in the us.
/Jimmy
There is always work for a good welder.
af2
Re: work in us
Post by af2 » Mon Apr 09, 2012 9:44 pm
My problem with the certs you state are not what is used in AWS. 1-2-3-4 and f-g. I will ask my son who obtained many certs for all welding.
GURU is only a name.
RamAirV
Re: work in us
Post by RamAirV » Sat Apr 21, 2012 10:20 pm
In addition to having the proper certifications, you need to get a sponsorship from the employer in the USA.
The employer also has to justify the hiring, in your case, he has to show proof to the US State Department that he has not been able to hire skilled welders in the USA.
http://travel.state.gov/visa/immigrants ... _1340.html
http://travel.state.gov/visa/fees/fees_ ... l?cid=9711
amazonic
Re: work in us
Post by amazonic » Tue Apr 24, 2012 10:06 am
3may i am going to work 3weeks in bahamas for a swedish company,Iam really looking forward to this :D
donc
Re: work in us
Post by donc » Tue Apr 24, 2012 1:37 pm
Texas, is the place to check for welders.
amazonic
Re: work in us
Post by amazonic » Fri Apr 27, 2012 2:15 pm
af2 wrote:My problem with the certs you state are not what is used in AWS. 1-2-3-4 and f-g. I will ask my son who obtained many certs for all welding.
I have AWS B2.1 SMAW 6G certification
rce4csh
Re: work in us
Post by rce4csh » Tue May 08, 2012 11:53 pm
First I would suggest you correct your typing to place US as capital letters! Welder types are by and large a very patriotic bunch and as such take things this with some displeasure.
Next I would make sure my skill set is good enough to easily pass and certify for AWS D-1.1 in the 3G and 4G positions at a minimum using the SMAW process with E-7018 electrodes. If you can do it, test with the one inch thick test plates for an unlimted thickness certification.
Following this, I would cert to AWS D-1.1 in FCAW process with Lincoln NR 232 as the electrode to prove your mettle.
Beyond that, certification to the API code for pipe in the 6GR position should get you in the door with those guys, But be prepared to retest for the pipe crowd on a job by job basis on something like a branch T. You do the fitting and the welding under direct observation of the inspector.
Most important! Is not that you have certs, but that you have demonstrated competence and efficiency in whatever you are certfied for without any bull or excuses!! Think of your cert like a driver's license, it only shows that you are capable of passing a test! How you weld everyday, your demonstrated competence and your personal demeanor on the job is what keeps you employed.
The very best thing you could do for yourself as a welder in the United States employed in the structural end of the game is to be able to have the knowledge and expertise to easily pass both the written and practical portions of the Los Angeles City welders certification for structural welding. If you can do this for Structural (D-1.1) Rebar (D-1.4) and Sheet Steel (D-1.3) with both SMAW and FCAW processes, you can pretty well get in the door. Study Jack Compton's guide to the LA City welders certification for more details.
