Timing light
Nick Campagna
Timing light
Post by Nick Campagna » Fri Jun 15, 2012 6:26 pm
The spring connector on my older, but still very good timing light has streached out and become wothless. Does anyone know how to fix or convert it to inductive pickup ?
Is the defect in what I see, or what I'm seeing with ?
Kevin Johnson
Re: Timing light
Post by Kevin Johnson » Mon Jun 18, 2012 8:14 am
Nick,
Can you disect an old/new sparkplug wire boot and use the clip from inside it?
Keith Morganstein
Re: Timing light
Post by Keith Morganstein » Wed Jun 20, 2012 7:07 pm
On a similar light. I used a spring I scrounged up and put a clip on the lead. (like an alligator clip, but wider)
OTOH, inductive versions of similar lights are cheap on ebay.
Nick Campagna
Re: Timing light
Post by Nick Campagna » Wed Jun 20, 2012 8:03 pm
I like those ideas. Thanks.
les327
Re: Timing light
Post by les327 » Thu Mar 21, 2013 8:52 pm
The older sears dialback lights are cheap and work verywell
One on ebay now
