tac rpm setting. readings
crazycuda
Post by crazycuda » Sat Jun 24, 2006 3:23 pm
Heres a dumb question and I am trying to figure how to word it. What is the rpm diference between 6 cyl setting and 8 cyl setting if the eng is an 8 cyl but the tac is set on 6 cyl.
A little more explination as best as i can. if an 8 cyl is turning 6000 rpm but the tac is set on 6 cyl scale what would the tac be showing as rpm.
John Mann
Action Automotive Inc
Sorry if I ask alot of questions, but you never stop learning if you ask questions
bill jones
Post by bill jones » Sat Jun 24, 2006 5:30 pm
-The math says it's a 1.3333333 difference (8 divided by 6 = 1.3333333) which means that you are sending 1.33333333 more pulses to the tach than you should be.
-so 6000 times 1.3333333 = 8000rpm.
-I just happen to have a tachometer on my ignition machine that has the 4-6 & 8 switch so I tested an 8 cylinder at 6000 rpm and the tachometer when set on 6 cylinder does indeed read close enough to 8000 to believe the math (if you use all seven 3's).
crazycuda
Post by crazycuda » Sun Jun 25, 2006 12:32 am
thanks, bill.
that saves my insanity LOL
John Mann
