rochester 2bbl carb problem
themotorshop
Post by themotorshop »
I got a Rochester 2bbl from ebay and rebuilt it, now I have installed it and it is pouring gas from the boosters before the motor has even been running,motor is on a test stand and I used the primer bulb to pump up the gas to the carb, wondering if it was originally missing a check ball or have done something else wrong, any help would be appreciated,thanks
Baprace
Re: rochester 2bbl carb problem
Post by Baprace »
pull the top off and look at the needle and make sure the float is closing, you may have to bend the float arm.
themotorshop
thanks I will, i like the profile pic,the man
Baprace
Post by Baprace »
What did you find ?
themotorshop
turned out that I was improperly watching my fuel system and using an outboard motor tank, and had a vent problem, the tank vent system was not working properly so I had to loosen the gas cap slightly to prevent pressure from building up and blowing fuel past the needle and seat, thanks
